12-30-2021 09:18 AM
Nest Pro will not heat correctly. You set to 75 (quite cold hear) and it shows 1.5+ hours to heat. Will not actually heat up past 69 or so. You have to keep resetting the system to get it to heat. Followed other posters suggestions and reset to factory but it just keeps running and onky heating to around 69.
This is so frustrating!
12-30-2021 12:31 PM
We’re having the same issue and are feeling very frustrated. We have it set to 70 degrees
but it’s 61 degrees currently and shows 1hr 20min to heat.
12-30-2021 05:36 PM - edited 12-30-2021 05:44 PM
Same problem here. It sounds like the Nest isn’t working properly.
01-24-2022 11:37 AM
Exact same issue here. I've adjust all the settings, including any eco and home/away. It got a tiny bit better. Now it doesn't drop to 62 or 64 while we sleep. We have it set to 71
