11-29-2023 07:12 AM
Is it possible to use a Nest Temperature Sensor as a home automation "Starter"? If not are there any plans to add support for this?
I have an isolated room that I would like to add a sensor into so that an electric space heater can be automated on and off.
Thanks.
12-06-2023 06:31 AM
Hello bbergan2276,
Welcome to the Google Nest Community Forum!
Using a Nest Temperature Sensor can be a great starting point for home automation. While the Nest Temperature Sensor is primarily designed with the Nest Learning Thermostat for enhancing comfort in different rooms, it may not directly support home automation for individual systems like an electric space heater. However, you can explore third-party solutions or other platforms to integrate your Nest ecosystem with smart plugs or other compatible devices for automated control.
Keep an eye on Nest updates here in the community, as future integrations might expand its capabilities.
