07-10-2024 02:38 PM
When I first setup my Learning Thermostat and connected the Sensor, it worked great for a few hours apparently, as 24hrs later I got notification the sensor was offline. So I tried all the trouble shooting. Changed batteries and everything. I can add the sensor, but the connection will not work. The sensor is sitting less than 2ft from the Thermostat so there shouldn't be any obstruction due to walls and such. What do I do? Is it a lemon?
07-13-2024 04:35 PM
Hi Kristine0818,
Thanks for reaching out to the Community. I am sorry that you are having issues with your Thermostat and your Nest Temperature Sensor. But no need to worry, help is here.
I understand that you already tried some basic troubleshooting steps for your Nest Temperature Sensor that isn't connecting. Here are some additional things you can try:
Double-Check Connection Essentials:
Reset and Re-add:
Advanced Troubleshooting:
Alternative Solutions:
Please follow this good article to Troubleshoot issues with the Nest Temperature Sensor. There are a few troubleshooting steps to fix the issue.
Let me know how it goes.
Mario
08-02-2024 07:54 AM
I am having the exact same problem except mine worked for about 6 months the first time. I've tried everything under the sun and nothing has worked. I even bought a new sensor thinking that was the problem, but the new sensor won't connect. So now I have 2 sensors that won't connect. What could be the issue? Help!
08-02-2024 11:01 AM
Hi @Ljpoov,
Thanks for posting in the community! Sorry to hear that your Nest Temperature sensor isn't connecting too. No worries, help is here! Have you tried the troubleshooting steps recommended above?
Keep me posted.
Axel.
08-02-2024 11:34 AM
All of them.I've looked for solutions all over the internet and tried everything. I'm so frustrated nothing works.
08-03-2024 10:25 AM
Hello @Ljpoov
I appreciate the detailed information you provided. Let's try to fix this!
Really sorry for all this inconvenience let me lend you a hand to find a solution. To continue assisting you, please fill out this form with all the necessary information. Once you've completed the form the specialist team will find a solution.
Feel free to reply to this post when you complete it. We are happy to help you.
Douglas
08-03-2024 11:20 AM
I just completed the form. I hope you can help me. I'm feeling deperate at this point.
08-06-2024 06:26 PM
It's been 3 days since I completed the form. Any suggestions?
08-06-2024 08:07 PM
Hello @Ljpoov,
Thank you for posting in the community.
I know how difficult it is that the Nest sensor won't connect, and I also apologize for not being reached by the specialist team yet but I just double-checked, and your form has been received, so I can assure you that you will be contacted this week.
Any question you may have, don't hesitate to tell me. Thank you.
Jorge
08-11-2024 07:56 PM
I have the exact same problem beginning around the same time (early July 2024) and have also tried the all the recommendations to no avail. The sensor had performed flawlessly for several years before dropping out at that point. Form submitted. Please help!
08-12-2024 11:02 AM
Hey Afrenchche,
Thanks for reaching out to the Google Community Forum.
You will be contacted shortly by a representative via email to offer additional support.
Daniel
08-15-2024 06:22 PM
I followed the instructions below, and this time it worked. I'm pretty sure I had done the same thing several times, so I'm not sure why it finally took, but it did.
Instructions:
I apologize for the inconvenience you're experiencing. I understand that despite trying several troubleshooting steps, your Nest Temperature Sensor can't be added correctly to the app.
