07-16-2024 04:38 PM
My Nest thermostat intermittently looses Wi-Fi and app connectivity as well as motion detection. USB charging works temporarily. I had a spare Nest thermostat learning and swapped them only to have the same issue. I even swapped the base plate to no avail. I installed a Nest power C wire connector at the furnace and still loosing battery voltage down to 3.666. The learning thermostat would not recognize the installation of the connector at the thermostat on the equipment menu. My HVAC still works fine is the good news. I’m ready to try a $20.00 battery bought on Amazon as a last resort. For what it’s worth, the Voc is 36.05v, Vin is 36.17v, lin 40mA(i).
07-19-2024 09:06 AM
Hello @Springer97
Thanks for reaching out to our Nest Community about your Nest thermostat battery. I apologize for all the inconvenience. I'm here to help you with that.
I completely understand this situation. Let me lend you a hand to find the solution.
Please fill out this form to forward this case to my support team. We are so happy to assist you.
Feel free to reply to this post when you complete it. We will contact you to continue searching for an answer.
Douglas.
