10-09-2023 04:39 AM
I had a honeywell thermostat that was blowing perfectly and then I switched to Nest thermostat and connected wiring as demonstrated below..AC was blowing well but today had to turn on heat and that started to blow cold air.
Nest Wiring
Honeywell Original Wiring
10-09-2023 10:57 AM
I had to call for help. I spoke to Chris and he was awesome. We had to reconnect the wires and reset the app and thermostat. Now I have heat without the condenser turning on. 🙂
10-09-2023 09:41 AM
I'm having the same issue. House got cold this weekend, Turned on the heat and it activated the condenser and the ac was running. I checked the wires, double checked again, also verified the wires in the furnace. The thermostat simply is broken
10-09-2023 10:57 AM
10-09-2023 08:47 PM
just disconnect the Y wire, reset and see if it works. It worked in my case
