Nest Thermostat E79 Error caused by Power Failure
DaveDenn
We have had a longstanding problem with our Gen 3 Nest thermostat at our cottage where we would randomly get a E79 no “c” wire error despite there is a “c” wire perfectly connected and the wiring verified numerous times.  We eventually suspected without solid evidence, not being present when it happens, the problem coincides with power outages (we get notifications from the hydro company) that may flash on and off a couple times.  We have the same thermostat at our home which didn’t seem to be afflicted the same way until NOW where we were present during a short 15 minute power outage and sure enough up came error E79 no “c”wire.
it is now clear that the Nest thermostat is the issue as we have the same problem at two different premises during short power outages.  As this knocks the furnace out of order and can only be fixed on location by turning the power to the furnace off and on, which is impossible if we’re not at that address, baring a satisfactory solution we will be forced to take out both thermostats and replace with another brand and likely switch our entire home eco-system away from Google.
AxelD
Hi DaveDenn,
Thanks for reaching out to the community! I'm sorry to hear you're encountering the E79 error every time you get a power outage and it affects your C-WIRE. I understand how frustrating it must be that the only troubleshooting solution seems to be manually turning the furnace off and on, which is impossible if you're not physically present. Wiring issues like this typically require a manual inspection and cannot be resolved remotely. I'm sorry to hear you're considering replacing your Nest Thermostats. I appreciate your feedback and I encourage you to share your thoughts. We'd love to hear from you.
Please let me know if you have any other questions.
Axel.
