Nest Thermostat Power Requirements?
Endlessknight
Greetings all,
I would like to install a Nest thermostat on an older heating  system that only has two wires, red and white. The furnace itself has no labels but I can put a multimeter on the red wire and find out what the output is. What's the minimum needed, volts/amps, to power a nest?
9 REPLIES 9
Houptee
Silver Product Expert
24 V AC is the standard for most HVAC thermostat wiring.
You really should pull a new 5 conductor thermostat wire so you can connect a C common wire.
The Nest needs a common to keep it powered.
If you take a pic of the heating system wires we can see if you have a place to connect a common wire.
Some hot water boilers that use zone valves can cause problems when the Nest draws power from the transformer do you have any zone valves?
Sounds like you might have an old-style milli-amp furnace. This type of furnace can not be controlled by the Nest thermostat without a little bit of rewiring.
You'll need an external 24Vac transformer, the Google Nest Power Connector, and possibly a relay.
This is the basic wiring that will need to be done.
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, Houptee and Patrick_Caezza.
Archie
aatienza
Archie
EdwardT
Hi Endlessknight,
Edward
Endlessknight
Hi All, thanks for the responses. They were very help. Been very busy with other things. I still haven't decided what to do
EdwardT
Hi Endlessknight,
Thanks for the update. Let us know if you have other questions and we'd be glad to assist.
Edward
EmersonB
Hello Endlessknight,
@archie, @Edward, @Patrick_Caezza and Houptee I appreciate your response.
Jhonleanmel
Mel
