01-18-2024 05:54 PM
My NEST 3 just gave up on me on the coldest night this year (- 9) degrees. I had to buy a new one and installed it; I was not aware that there was the migration with google and the setup became a nightmare.
I need the following help:
How do I install two iPhones to operate two different NEST 3? Where can I find step by step instructions? I am already that far to just return the Thermostats and buy something else.
Thank for any help.
01-22-2024 11:09 AM
Hi ewillmes,
Thanks for reaching out to us. First, you must create two different Nest accounts so that you can add your two Nest Learning Thermostats separately. Then, follow the steps in the add your Nest Thermostat to the Nest app guide.
Let us know if that helps.
