06-04-2024 09:33 PM
I have a Nest Learning Thermostat. I needed to change the WiFi and reinstall the app on my phone. I was unable until I reset the thermostat and now the Fan Setting is gone. How do I get the fan setting back on? AC just isn't doing it's job without the fan. The fan setting has been there since installation a few years ago and worked fine. Totally gone after reset. Thank you so much for any help.
06-05-2024 12:33 AM
It seems like your Nest Thermostat lost its fan settings after a reset, which can be frustrating, especially in hot weather. To resolve this issue, you might want to try accessing the settings directly on your Nest Thermostat. Look for the fan settings option in the menu and see if you can re-enable it from there.
If you're still having trouble, reaching out to Nest customer support could provide further assistance tailored to your situation. They may be able to walk you through troubleshooting steps or offer additional solutions to help restore your fan settings.
I hope you're able to resolve this issue quickly and get your AC back to its optimal performance!
