Nest Thermostat will not manually heat house when in "HEAT STAGE 2"???
DEGO
We have 2 Nest thermostats V3 and each essentially locks us out of heating the house when we move the thermostat to higher heat.  Says there is a delay for "HEAT STAGE 2".   I have reviewed endless posts and cannot find the answer.  I have wired both Nests correctly.
I have also gone into the schedule and moved the time/temp to allow heat now to start.....does not work.  Please help.  Thanks, Scott
2 REPLIES 2
Ryan_G
Hi DEGO,
Thank you for reaching out and I'm sorry to hear about what happened.
We could further check by getting a photo of your current thermostat wiring. Also, go to settings > equipment then select the right heat source and fuel type.
Let me know how it goes.
Ryan
Ryan_G
Hey DEGO,
I just wanted to follow up and see if anyone is still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Ryan
