Nest Thermostats Clicking noise
MonPop
Hi there, ever since I installed the Nest Learning Thermostats in my condo a couple months ago, I started hearing these clicking noises.
The noises were intermittent when the AC was on in the summer, but now that the building switched to Heating, I hear the clicking continuously and it’s really bothering me (I also had to remove the Y1 wire at that time as I had the E80 error which was a nuisance).
Is the clicking noise a compatibility issue with my fan coil unit? I read here that other people had the same issues and it’s about voltage and power issues, etc. is there any risk of damaging my fan coil units?
If there is no easy fix for this, I would like to return the thermostats back to Google and get a refund (I’m past the Best Buy 30day return policy).
Please advise.
11 REPLIES 11
EdwardT
Hi MonPop,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. I'd love to know more about this and I have a few questions:
  • What type of Nest Thermostat do you have?
  • How is your Nest Thermostat wired?
If you haven't yet, please try the troubleshooting steps on this article to isolate the issue.
Edward
aatienza
I appreciate the help, Edward.
Archie
MonPop
Yes, still need help. I have the Nest Learning Thermostats. My fan coil units are Unilux LE450. Do you know if they are compatible?
EdwardT
Hi MonPop,
Thanks for the response. Could you share how your Nest Thermostat is wired? Also, please check the power readings of your Nest Thermostat. You could find this info by going to Settings > Technical Info > Power.
Edward
EdwardT
Hey MonPop,
Edward
EdwardT
Hi MonPop,
Edward
MonPop
Here are my thermostats power readings:
Voc 31.78V
Vin 16.87V
Lin 20 mA
MonPop
Wires: Y1 cool, G fan, Rc power, W1 heat
EdwardT
Hi MonPop,
Thanks for the response. Your power readings look fine but it's possible that you may need a C wire for your Nest thermostat. We'd like to know more about this. Please fill out this form so we could investigate further.
Edward
Jeff
Hi MonPop,
I just wanted to jump in real fast to see if you saw Edward's reply and to see if you were able to get that form filled out. If you need any assistance with that, just let us know.
Jeff
Jeff
Jeff
