12-04-2022 11:30 AM
My indoor temperature fell to 57-degree F this morning according to multiple sensors in the house. However, my Nest says it's 66 with a target temperature set to 67. Therefore, I had not heat last night. I was able to get heat pump running by turning up the target temperature higher than 67. The actual indoor temperature is 59 now but my Nest still says it's 66.
12-04-2022 12:44 PM
Have you tried to factory reset your thermostat?
12-04-2022 03:56 PM
Yes I did. It required me to remove and readd the device and the whole nine yard of setups. But problem remains. It appears that the Nest is always 8 degree higher than actual. So I am raising the target temperature 8 degree higher to get by.
12-08-2022 12:01 PM
12-12-2022 08:15 AM
Hi cfjwang,
I'm checking back in — how's it going? Have you had a chance to fill out the form? Let us know so we can assist you right away.
12-13-2022 09:07 AM
Hello cfjwang,
I'm checking in to make sure that you've seen our response. If you have any further questions or concerns, please let us know before we lock this thread in 24 hours.
