Nest e thermostat wont power up after installation
Deacon38
I just installed the nest e thermostat and it doesn't power up
I got it to power up, but thanks. I plugged it in to charge and nothing happened so I left it and after a while the red light came on and I plugged it into the base and set it up and it has worked since. Thanks
Can you post a picture of the original thermostat's wiring?
Check the control board inside of the furnace/air handler for a blown fuse.
Jeran
Hey there Deacon38,
I'm just checking up on this thread, I'm glad to hear you were able to resolve this! In that case, do you have any more questions or need any additional help?
Thank you for helping out on this thread, Patrick_Caezza!
Jeran
