02-18-2023 09:04 AM
Nest thermostat can’t connect , says H71 error code , no lights on the nest heat link at all
02-19-2023 07:35 AM
Hi there! I'm sorry to hear about this, but I'm here to help. Could you please answer to the following set of questions and try the steps?
What type of Nest Thermostat do you have?
Have you recently had service or maintenance on your electrical, plumbing, or heating system?
Have you tried any troubleshooting steps before contacting us?
How many zones are present in your setup? Meaning how many thermostats do you have.
Check if there are current power outages.
Check if the breaker switches are set to on.
Turn the breaker switches off and on.
Turn on manual mode by pressing the button of the Heat Link.
02-22-2023 07:40 AM
Hi there! Have you managed to check my last message?
02-22-2023 02:25 PM
Hi Paul, thanks for connecting … it appears my hardware was faulty so o got a new heat link installed under warranty so all working again now
02-23-2023 12:25 AM
Woohoo! We're so glad to hear this. I'll have to close this thread for now, but no worries you can reach back if anything comes up. Have a nice one!
