02-19-2023 08:55 PM
I have a hydronic system with three heat link units. One of them has no lights at all and it's not providing any power to the thermostat. There is power to the heat link and I have tried to cycle the power and hold the button down to reset. None of these things helped. The heat link unit is completely dead. Installed in late 2019. Any suggestions?
02-20-2023 07:00 AM
Hi there, I'm very sorry to hear about this, but no worries, I'll do my best to help you sort this issue out. I've sent an email with a form. Please fill the form out in order to open a case for you. Also, please let me know here once you've completed the form. Meanwhile, could you please provide me with these details?
How many zones are present in the setup?
02-20-2023 10:37 AM
02-20-2023 10:57 AM
Thanks for letting me know. Just to have these details confirmed in your case: did you try any troubleshooting steps like checking that the breaker switches are set to on, turning the fuse board switches (circuit breakers) off and on or turning on Manual Mode to verify boiler activation?
02-20-2023 11:03 AM
Breaker switches are on. The two other units are powered from the same circuit and they are working. A multi meter has been used to verify that the unit is receiving correct power. Pressing the button for manual mode does not work. No lights or response.
02-21-2023 07:18 AM
Thank you for all the information. I would like to create a case for you so we can go through a few more details on our end. Would it be ok if I contacted you over the email associated with your account here?
02-21-2023 11:39 AM
No problem Alex.
02-22-2023 02:14 AM
Hi there @CCM75! I just sent you an email with some instructions, please follow them and reply here when you're done with it.
02-22-2023 03:54 AM
All done thanks Paul.
02-22-2023 04:10 AM
Thanks, it's all good. We checked and your thermostat seems to be out of warranty since February 2022, but we'll be able to process a replacement for it, as an exception. The issue is that we cannot issue replacements in Australia as it's not a supported country. We'd be able though, to give you the replacement if you send it in one of our supported countries in Europe, we saw that the thermostat was originally for the UK market, so maybe you could send it there, but the costs of shipping your Heat Link to the UK and shipping the replacement from the UK to Australia, will not be supported by us.
02-22-2023 11:24 AM
02-22-2023 11:25 AM
Well that’s disappointing.
02-23-2023 12:54 AM
We're so sorry for any inconvenience this may have caused and we're looking forward into selling Thermostats in more countries. I'll have to close the thread for now, but feel free to reach back whenever. Have a nice one and stay safe!
