01-31-2022 01:46 PM
My zone 1 heatlink has just lost power. Zone 2 heatlink still working. I've tried turning off fused spur supplying boiler, left for a few minutes and turned back on but nothing happens to the zone 1 heatlink. The thermostat has now gone dead aswell as low battery. I've read that this is a known problem, can this be sorted by nest ASAP please, as hot water is on my zone 1.
Thanks in advance.
02-08-2022 04:48 AM
Hi there. Thanks for reaching out. Good job with the troubleshooting. Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
02-11-2022 04:55 AM
Hello again. Just checking in. Do you still need my help?
