05-18-2022 06:54 PM
I recently installed two Nest thermostats to run our two HVAC systems. During installation, both displayed temps 4-5 degrees cooler than the older thermostats. I expected maybe a degree difference but not 4-5. A/C used to come on at 80, but now it's 75-76. It would be too warm and uncomfortable if we let the Nest get to 80. Is this variance normal? It has no impact because it's more about feel than the number, so it is what it is, I'm just curious. Thank you!
06-07-2022 09:50 AM
Hope this helps!
Kind regards,
Ryan
