05-24-2024 08:44 PM
05-28-2024 09:39 AM
Hi @mikevech,
Thanks for reaching out here in the community! I'm sorry to hear your Nest thermostat is blowing hot air instead of cool air. Help is here!
To better assist you, I'd like to ask a few questions:
Please keep me posted.
Jenniffer
05-28-2024 03:57 PM
05-29-2024 12:52 PM
Hi @mikevech,
Thanks for following up and for all the information. Let's try to fix this!
To attach a photo here in the community thread, look for the camera icon in the reply box where you type your message. It says 'Insert photos' and you will be able to select the files.
To troubleshoot why your Nest thermostat might be blowing hot air instead of cool air, I'd suggest the following:
Let me know how it goes.
Jenniffer
05-29-2024 05:38 PM
humidifier is removed completely so not sure if I have an extra wires or not
05-31-2024 11:31 AM - edited 05-31-2024 11:43 AM
Hi @mikevech,
Thanks for reaching out to the community and for the photo! I apologize for the delay.
I noticed a wire connected to the asterisk (*) terminal on your Nest thermostat, which is commonly used for humidifiers. Here's what you can do:
Check if the system is set to single fuel or dual fuel:
Now, let's adjust the heat pump orientation settings:
For more information, you can check out the next article: Troubleshoot heat pump issues.
Jenniffer
