02-20-2023 01:20 PM
Hooked up my Nest thermostat and it says low power. It was working for a minute now all I see on the thermostat is the google sign and my phone won’t let me turn the heat on. Any idea??
02-20-2023 07:55 PM
Which Nest thermostat do you have?
How did you wire it?
Can you post a picture of the original thermostat's wiring?
02-21-2023 02:59 AM
03-04-2023 07:44 PM
I don't see a C wire in the original thermostat's wiring. I highly recommend always having a C wire to ensure you don't have any type of power problems.
Your low-power message could be a result of not having a C wire. Check and see if there is a spare wire going to the furnace. Then look in the furnace and see if there is a C terminal that you can connect to. If there is one, connect the spare wire and the C terminal to the thermostat.
You can use the Google Nest Power Connector if there is no spare wire.
03-07-2023 11:56 AM
Chiming in — could you please provide the information asked by Mark? It will help us to check it further. Also, you can get the suggestion by Patrick_Caezza to make sure you won't encounter any power issues in the future. Additionally, you can charge your thermostat using a micro USB cable for at least an hour to see if it will maintain the voltage by the wires connected to your thermostat.
I appreciate your help, Mark and @Patrick_Caezza.
03-10-2023 03:29 PM
Hi Merk1,
I'm checking in to make sure that you've seen our response. Please let us know if you are still having trouble from here, as I would be happy to take a closer look and assist you further.
03-11-2023 03:53 PM
Hello Merk1,
02-21-2023 03:01 AM
Pat I bought the smart learning Nest. It keeps saying low power
03-04-2023 09:12 AM
Hello folks,
Thanks for the help, @Patrick_Caezza.
@Merk1, thanks for sharing the photo. I'd love to know more about this as well.
Could you also share with us a photo of your Nest Thermostat's wiring? Also, please check its power readouts. You can find this in your actual thermostat's Technical Info settings.
