Nest learning thermostat. Connected and clicks but boiker wont fire
Gillian
I can hear the heat link box click but heating not coming on.   Will come on if input on manually
2 REPLIES 2
CristianC
Hi Gillian,
Thanks for reaching out. I'll do my best to get this resolved for you.
When did this issue happen? How long after the installation?
If the boiler activated while you pressed the Nest button on the Heat Link ( in manual mode ) and you also heard the click sound while turning off/on the heating from the thermostat display, you might have a stuck heating valve. I recommend to reach out to a local installer or a Nest Pro to take a look at it.
Let me know how it goes,
Cristian
AlexD
Hi, I wanted to check in.
How has it been going with your thermostat? Make sure to let us know if you need any further assistance.
