01-14-2026 03:56 PM
Has anyone had any success getting a Nest thermostat to work with an older Fujitsu ductless mini-split heat pump?
01-18-2026 05:15 PM
Hi @airhar,
Thank you for posting in the community. I understand you are looking for confirmation if the Nest Thermostats are compatible with a Fujitsu ductless mini-split heat pump. I'm happy to assist.
To gather the necessary information, please answer the following questions:
I'll be waiting for your reply.
Derick.
01-19-2026 09:57 AM
We have not yet committed to a particular model...we'd be willing to purchase whichever model is compatible.
01-20-2026 08:43 PM - edited 01-20-2026 10:12 PM
Hi there!
Thanks for your reply. I appreciate your interest in the Nest Thermostat for your Fujitsu ductless mini-split. To provide you with the most accurate compatibility information before you commit to a model, please reply with the following details:
Derick.
01-21-2026 11:22 AM
The indoor unit is a AUU18RCLX ceiling cassette. The outdoor unit is a AOU18RLX
01-21-2026 11:02 PM
Hi there!
Thanks for your reply. I appreciate you sharing the model number of your HVAC system. After reviewing the specifications for your Fujitsu AUU18RCLX ceiling cassette and AOU18RLX outdoor unit, I can confirm that directly connecting a Nest Thermostat to a Fujitsu mini-split is not a standard installation because these systems use different communication voltages. To ensure your system is compatible and to avoid damaging your equipment, I recommend contacting a local HVAC technician who specializes in mini-split systems. They can determine if there is a specific way to bridge the connection between the Nest Thermostat and the Fujitsu unit.
Please let me know if you have any other questions.
Derick.
