05-23-2023 07:21 PM
My nest is set to 68. It says my house is 73 and will take 1 h 10 min to cool to 68. The blower is not on. The temperature has not changed at all.
05-31-2023 09:10 AM
Hi mwilliams1250,
Thanks for reaching out. I'm sorry for the delay. A few questions: what type of Nest Thermostat do you have? You can visit this link to check what type of thermostat you have. Do you see any messages or code on your thermostat or in the app?
06-03-2023 03:54 PM
Hello everyone,
@mwilliams1250, I'm dropping by to ensure that everything is covered here. How's it going with your Nest Thermostat? We would appreciate it if you could share the information we’re asking above. So that we could take a closer look and assist you further.
I appreciate the help, Jenelyn.
06-03-2023 04:01 PM
Sorry! Didn't see the replies. It is going terrible. It is the 3rd generation. Right now it's set to.70. Has been set to 70 all day but the internal temperature is 75. No messages or code on thermostat. I do keep getting an email message that says "Your A/C system likely failed to cool your home
When the A/C was on between 5:35 AM and 10:25 AM on May 30, 2023, your home got 4°F warmer. This is higher than expected based on your local weather and recent A/C system performance. Learn more
06-06-2023 03:20 PM
Thanks for looking into this, Jenelyn and Emerson.
@mwilliams1250, it appears to be a power-related concern that could cause this. Please gather your thermostat's power reading in the Technical Info settings. Also, what type of system do you have? (Heat Pump or Conventional Type)
For heat pumps:
For conventional types:
Let us know how it goes.
06-10-2023 10:04 AM
Hi mwilliams1250,
06-11-2023 02:50 PM
It's been a few days since your last reply — we're going to lock the thread within 24 hours. If you have further concerns, please feel free to create a new post.
Kind regards,
Dan
