3 weeks ago
Good Day
As of yesterday our nest thermostat is not changing the temperature when moving the outer ring however it functions normally from the iOS app. I tried restarting it but it does not change anything. I also checked the voltage and it show 3.93 volts the software version is 5.9.4-5
not sure what to do anymore
thanks
2 weeks ago
Hi @tyacoub,
Thanks for your post on the community! I understand that you're having some issues with your Nest thermostat because it is not changing the temperature when you use the outer ring. I appreciate that you've already tried some steps, like restarting the thermostat, and also that the device is working fine on the app; that's really helpful! Let me handle this for you from here.
Before we continue, I need some relevant information:
I'll be happy to help you once you provide this information.
Debora
