Nest power failure
Cson88
Hi, my nest and heat link has no power and looks like a similar problem that a lot of people are sharing. Is there anything that can be checked or done or is a replacement required?
Rusell
Hi Cson88,
Thank you for posting in the community. I understand that your Nest thermostat and heat link don't have power. I'm happy to help you!
To help me find the best solution, I'll need to ask you a few questions:
  • What type of Nest thermostat do you have?
  • What is the color of your Heat Link's light?
  • How is the Heat Link being powered?
  • What troubleshooting steps have you done so far?
  • When did the inconvenience start?
  • Is there any error code or message?
  • To help us get a better picture of what's happening, do you mind sharing a photo of your Nest thermostat wiring?
Keep me posted.
Rusell.
Cson88
Hi, problem started 8th March. Power is no longer displaying on nest and the heat link has no light available. Looks like the common problem that has been reported. I am without heat in my home unless I manually drive the valves open myself.y neighbour also had the same issue and he got his 2 nests replaced.
if this is a known issue, I would be expecting the same.
regards,
ciaran
Rusell
Hi Cson88,
Thank you for your response. I appreciate the information you shared, but I still need some relevant details to provide you with the correct troubleshooting. Therefore, please kindly answer the following questions:
Keep me posted.
Rusell.
