01-05-2024 06:40 AM
Nest is set to have turned on an hour ago and heat to 67. The nest says the temp is 61. The heat is not running but it says it will reach 67 in 1.5 hours. It does not respond and start the furnace when I turn up the temp to 70 or 75. We have owned it for three years without a problem. It has recently done this every day. Never fully heating ( always delaying it for .5-1.5 hours), and not allowing us to manually adjust the temp (and heat NOW). Feels like its a new update problem (but I do see that a lot of people had the same issue in 2022 but with no resolution other than wipe it and start over). I already sent a message to the help link I found on another similar message.
Software version 6.2-27
Cool - Y1
Fan - G
Heat- W1
24V Common - C
Power - Rh
01-08-2024 02:41 PM
Hi Ruraldave,
Thanks for reaching out to us. I'm sorry to hear that you're experiencing issues with your Nest Thermostat not responding correctly and delaying heating. Here's what you can do:
Let us know how it goes.
