10-30-2023 11:31 AM
The thermostat worked well for a couple month then lost network connection, message with W5 code displayed. Reset the thermostat several times with no success. Reset to factory setting did not fix the problem. Network / wifi router works ok, I have another same kind of thermostat (controlling another temperature zone) which perfectly works in the same network. Any suggestions?
10-30-2023 01:59 PM
It sounds like you've already tried these steps?
Troubleshoot a Nest thermostat w5 code - Google Nest Help
If the issue persists after trying those steps, contact the Google Nest support team directly.
As it mentions in the article, the best thing to do is have your thermostat’s serial number ready to give to the support agent before you call. To find your thermostat’s serial number, pull the display off the base and flip it over. The serial number is above the QR code on the back of the display. Be sure to mention to the agent you've already tried restarting the thermostat.
