05-02-2025 02:54 PM
Nest says it is cooling, but the AC unit has not turned on and the blower is not on.
05-05-2025 02:06 PM
Hi Pglake,
Thank you for posting in the community. I understand that your Nest thermostat says it's cooling, but the AC and blower aren't on. Help is here!
At the moment, I'd like to ask you a few questions to give the correct troubleshooting:
Keep me posted.
Rusell.
05-08-2025 09:36 PM
Same issue, gen 4, standard ac condenser and furnace, this is 100% a software issue, so you don't need a photo, about a week ago? Maybe a little longer, no power code.
I want to say I saw an update and a couple days after that it's like it would say that it's cooling, but wasn't doing any cooling. I turned off every smart feature and did a reboot and after maybe an hour the compressor finally kicked on. But everything was working wonderfully for almost a year prior to the issues a arising in the last week.
05-09-2025 03:19 PM - edited 05-09-2025 06:48 PM
Hi Loathesong,
Thank you for posting in the community. I'm sorry to hear that you're experiencing the same inconvenience where your Nest Learning Thermostat (4th gen) says it's cooling, but it isn't cooling. I appreciate the troubleshooting you've done so far. Help is here!
To move forward, I'd like to ask for some details to provide you with the correct troubleshooting:
The pictures will help me determine two things: whether the issue is with the software or the hardware, and the compatibility.
Keep me posted.
Rusell.
