Nest thermostat heat stage 2 does not heat
manosek
It's been working fine for years. Now the heating stops and the dial reads heat stage 2, but I have no stage 2 system. Why would this start happening, and how can I fix it?
7 REPLIES 7
Sorry to hear about the trouble. I wanted to follow up and see if I could be of any help. There is a chance you may need to reconfigure your wire setup. You can do that by following the steps here.
  1. Go to Settings and then Factory Reset .
  2. Begin thermostat setup with the Home app again. On the main screen, tap Add Add and then Set up a Nest product.
  3. Re-enter all the wires connected to your thermostat. Double check your account for any unconfigured wires.
Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Hello manosek,
I'm checking back in. Were you able to do the steps shared by Jake? I'd be glad to hear from you — we'd like to make sure everything is working.
Hi manosek,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
manosek
HVAC guy checked the Nest - all o.k., but wired as if I had a stage 2, which I don't. Furnace regulator failed, new one ordered. Hope it fixes the problem (fingers crossed).
Hello manosek,
Thanks for getting back to us. I'm glad that you were able to reach out to an HVAC expert and were able to figure out what caused the issue. Please keep us posted once the new regulator is installed and let us know how it goes.
Hi manosek,
Chiming in to check if you have additional questions or concerns, as we will be locking this thread in 24 hours.
