Nest thermostat hot water not swictching off
MadMick
Hi heating all set and working from app on/ off
hot water not switching of on heat link.
orange droplet on themostat dose not turn off even when no demand or removing wire from terminal 6
Frustratedddd
What makes you think the light would go off by removing the connection at terminal 6? Terminal 6 is the connection feeding the water circuit, the outgoing side of the relay!
Has the system been working OK up until now?
Are you aware also the water schedule is set from 5pm, is that activated? Try dissable if it is.
Have you tried a restart of the display, NOT a reset?
