11-28-2023 06:55 AM
I recently added our hot water schedule for the winter in Ireland but the schedule is active and the thermostat is not heating the water. It has worked fine until now (installed 2016).
Can you provide a resolution for us? Hot water boost works fine.
11-29-2023 02:32 AM
Hi there and thanks for reaching our Community. I'm really sorry to hear about your issue, but I'll do my best to help you out. Just to confirm, the hot water boost from the thermostat or the app works fine, is just the schedule that does not activate the water, right?
11-29-2023 03:41 AM
Hi, yes boost works fine. The schedule seems to have worked this morning, but this was the first time in a week that I noticed. There was a message on the thermostat screens that I had to say "No Thanks" to around auto efficiency for winter. Perhaps this was overriding the schedule?
11-29-2023 05:26 AM
There is a possibility, yes. Can you please also check if the Auto-Schedule feature is on? Additionally, if the schedule has been added recently, there is also a chance that is still calibrating.
12-01-2023 07:32 AM
Hi, I wanted to check in. Is there anything else I can try and assist with? How are things going with your device?
12-01-2023 07:34 AM
Hi Alex, I selected NO to the Auto Enhanced feature that was on my thermostats and that seems to have resolved the issue. Thanks.
12-01-2023 07:51 AM
That's great to hear. Make sure to keep an eye on it and if something comes up, reach out here or on any of our channels.
