Nest thermostat lights orange to heat but doesn’t turn on boiler
Willritchie11
I’ve had this issue for a week or so now whereby I noticed the boiler just isn’t turning on in the morning despite the schedule not changing. The thermostat lights up orange as if it’s heating, but no boiler activity. I’ve tried restarting (not resetting) the heat link and that does get it working immediately, however after a few hours it stops working again. Any help or advice appreciated!
Frustratedddd
Sounds like interference from something. Have you installed, purchased, changed anything just befroe the problem? There are a lot of reasons for this, and a common one is DECT phones, new router, any metal work etc., even microwaves.
