07-10-2024 08:02 PM
I have a Nest Thermostat with the Power Connector connected. Still getting low battery message. Shouldn’t the Power Connector fix this issue?
07-14-2024 12:00 PM
Hi there!
Sounds like your Nest thermostat is showing a low battery message even with the Power Connector installed. Let's get that fixed and keep you comfortable.
Brandon.
