03-04-2023 09:05 AM
I have my next thermostats wired correctly. I have the power connector wired correctly. All tests show normal and fine in configuration menus. It still goes through new batteries about every 2-3 weeks. Even rechargeable ones which I thought the power connector would charge for me. That may just be rumor on the net. Please advise. I like the thermostat but don't want to feed it batteries all the time. -George
03-04-2023 10:45 AM
I've been having the exact same problem. It was working 100% fine for the past year, but about a month ago I started getting battery warnings and I've been needing to replace them every ~2 weeks ever since. Nothing has changed anywhere in my system and all of the wiring is fine.
03-04-2023 11:54 AM
I have been getting the same message, and trying to find an answer for a couple months, because I have a battery tester that says they are fine, full of power. Something triggers a change in the way the thermostat reads/reacts to the batteries. There does not seem to be an answer available here on the boards.
03-04-2023 12:33 PM
Thanks for the replies. If I could just ignore it, fine, but it eventually goes offline until new batteries are put it so I don't think their levels are up. I think they just get drained. It's not using the power from the power connector although it shows fine in the menu. Any other ideas besides replace it?
03-04-2023 08:18 PM
How do you have the Nest thermostat and power connector wired?
What type of system do you have? Heat/cool, heat only, boiler?
You can not use rechargeable batteries in the Google Nest Thermostat as they supply a lower voltage than alkaline batteries.
03-05-2023 09:55 AM
Heat only, gas furnace. All connections verified and shown to be correct in image below. Do you see anything out of place. I see enough folks online having the same issue there seems to be a systemic issue.
03-08-2023 09:50 PM
Anything look out of place?
03-11-2023 01:03 PM
Hello folks,
I'm sorry to hear you're all having the same issues with your Nest Thermostat. But I wanted to stop by and see how I could help.
@Georgerb, could you please try resetting your thermostat to its default settings? This will remove your account information and might help us clear the low battery prompt. Here's your guide on how to reset and set up your thermostat. Keep me posted if that helps.
@jeffman and @TB51, a few questions: does it also have a C wire connected or a Nest Power Connector installed? Could you please share with us the power readouts on your thermostat? Also, please try to reset it as well and let us know if it works. I'll look forward to your response.
Thanks for the help here, @Patrick_Caezza.
03-12-2023 07:44 AM
Thanks Mark -- here are my power readouts:
Vin: 33.120 V, Iin: 385, PS: Y-385, YP-25
I use the Power Connector, no C wire. The wiring info says I'm connected to Y(P)-W-G-R, and it also detects the power connector ("Nest Power Connector Detected").
I've already tried a reset but I didn't see an improvement unfortunately.
03-12-2023 07:54 AM
Mark, I already answered your questions above along with images. This is happening to many people in a consistent way.
George
BTW: Are you a bot?
03-12-2023 11:17 AM
From this support page https://support.google.com/googlenest/answer/9241211?hl=en-CA#zippy=%2Cpower, typical Iin with no C wire is 20-40, but mine is 385. Ten times higher than it should be. Why is it drawing so much current, and does this explain the high battery drain?
03-12-2023 12:15 PM
Jeff, mine is 385 as well. You may be onto something with current draw. Seems support should be able to guide us here.
03-16-2023 11:02 AM
Thanks for the details, and I understand your thoughts about your Nest Thermostat's battery being drained even with a C-wire or a Nest Power Connector installed, but I'd love to know more about this.
Could you please check your thermostat's battery health?
Keep me posted.
03-16-2023 12:24 PM
Thanks Mark. The impedance is 1279 mOhm. Not quite 1500 but I will try that brand next time I replace these regardless.
As an aside, would using a C wire instead of the power connector have any advantage in this situation, or would it still be subject to the same conditions, e.g. would it need to target <1500 mOhm with a C wire?
03-16-2023 03:31 PM
Hello jeffman,
I appreciate you checking it. Technically, both the Nest Power Connector and Common Wire have the same function: to deliver constant power to your thermostat and avoid power issues with your HVAC system. But they differ on how convenient the installation would be. Please take a look at this article and let us know if you need more help.
03-19-2023 04:43 PM
03-20-2023 05:22 PM
Hello there,
03-20-2023 08:53 PM
It's still not working. Everything looks normal as shown in my images above. Just drained last pair of batteries (correct type) again. Shows LOW BATTERY, REPLACE NOW. Is it a bad thermostat? No one seems to be able to help solve this issue. Please advise.
03-21-2023 01:05 PM
Hi Georgerb,
I'm sorry for the experience. We'd like to take a look at this for you.
Could you please fill out this form with the needed information? A member of our support team will be in touch over email to help.
03-24-2023 03:21 PM
Hey everyone,
@Georgerb, we wanted to follow up and see if you were able to fill out the form? Let us know if you have additional questions.
I appreciate the help, Patrick_Caezza, Mark and Jenelyn.
03-25-2023 08:35 AM
I filled out the form but it just asked me to repeat everything I said in this thread. Time now for a solution please. -George
04-06-2023 04:42 PM
Thank you for your patience, @Georgerb. A member of our upper team will contact you via email. Also, please continue the conversation there and don't forget to check the spam or junk folder for the updates.
@TB51 and @jeffman, I wanted to ensure that everything was covered here. Please let us know if you need more help.
04-10-2023 11:19 AM
Checking if you still need help. Please let us know if you have further questions or concerns.
I appreciate your help, Mark.
04-11-2023 11:36 AM
Hello there,
