04-01-2024 08:39 AM
I am having a problem connecting my nest thermostat to the WiFi. A previous user had been using this nest successfully connected to WiFi- with the same WiFi network name and password. They then disconnected from this thermostat and when I try to connect it to the internet the thermostat says the password has changed for the network. Although I am using the correct network name and password. Other non nest devices have been successfully paired with the WiFi recently. This also happens for the other nest thermostat in my house.
04-01-2024 12:37 PM
Hi carolineonastor,
Thanks for the update. If you've tried all the troubleshooting steps in the article and your Nest thermostat is still offline, we're here to help! Feel free to call us to connect with one of our specialists for further assistance.
Jenny
04-01-2024 10:36 AM
Hi carolineonastor,
Thanks for reaching out! I apologize you're having trouble with your Nest thermostat's Wi-Fi connection. Here are some troubleshooting steps that might help:
1. Check basic troubleshooting:
2. Check your Wi-Fi network:
3. Restart your Nest thermostat:
Please let me know if you've tried these steps and if you're still having trouble. I'm happy to help further.
Jenny
04-01-2024 11:13 AM
Thank you for the reply- based on viewing previous conversations here, I have done the items you suggest, with no change.
04-01-2024 12:37 PM
Hi carolineonastor,
Jenny
