Nest thinks it’s working fine, but no hot water
markbenjamins
My Nest doesn’t seem to think/report that there is a problem - no reported communication issues or faults - but the hot water signals are not switching my boiler on. Heating signals will, but not hot water. When I press the override button on the receiver unit, it works (both hot water and heating, of course), but not hot water. Very strange. Any ideas?
Katiesatt
Replying to mention same issue. Have searched for similar posts with no luck. Did you resolve this?
Some suggest that hw only successfully triggers if heating is on - this can’t be true for us because it’s been fine all summer til now.
Others have reported that “it just started working”. Can’t see any actual solutions.
I wanted to check in and see if you managed to see Mel's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
Jhonleanmel
Thanks for posting, and sorry for the delay.
@Katiesatt, thanks for the help.
@markbenjamins, how is your Nest Thermostat? Are you still having issues
Mel
