No heat using nest learning 3rd gen with heat pump
dnnm16
I have an electric heat pump system. It worked fine with the original thermostat. I switched over to  nest learning third generation and it's only blowing out cool air. Attached are two pics of my original wiring and my nest wiring. I can't get my heat to turn on. I switch B to O for heat pump setting based on troubleshooting recommendations. I've been looking through all the forums but no answer. I'm not sure if it's because of the heat pump or a compatibility issue.
8 REPLIES 8
Your system uses the B option for the changeover valve and you need to change that in the Nest.
  1. On your thermostat, go to Settings.
  2. Select Equipment.
  3. Select Continue > Continue.
  4. Select Heat Pump.
  5. The Nest Thermostat defaults to an O setting for heat pumps.
    • Select B.
  6. To make sure the issue is resolved, test your heating and cooling again.
So, I started out in B and switched to O after reading it on the troubleshooting forum. However, it's back to B again with no changes.
Maybe the wiring at the terminal block on the control board in the furnace/air handler is wired a little differently. Take a look there and see if the wire labels match up, post a picture if you will.
Ryan_G
Hi dnnm16,
Thanks for reaching out here in the community.
I'd like to jump in here and check if you've seen Patrick_Caezza's response. If you have further questions, let us know by replying to this thread.
Ryan
dnnm16
I havent looked at my furnace yet. I will look at it next week when I'm able to access it.
Ryan_G
Hi dnnm16,
Thanks for your reply and I am sorry for the delay.
I am looking forward for your next reply once you've checked the main board from the furnace.
Ryan
Ryan_G
Hey dnnm16,
Ryan
MelbaDT
We haven't heard from you in a while so we'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
