10-18-2023 02:16 PM
everything was fine then hot water stopped working. Plumber advised the nest was broken so we bought a new one but the issue is the same. Heat working fine but boiler not turning on when we boost hot water. Hot water schedule doesn’t trigger boiler either. We have a gas boiler. Can you help - it just stopped working ! Thanks
10-19-2023 01:01 AM
Hi there and thanks for reaching our Community. I'm really sorry to hear about your issue, but I'll do my best to help you out. Thanks for all the info provided so far, but can you please tell me if you have a separate tank for hot water as well?
10-19-2023 07:07 AM
Yes I have a gas boiler and a hot water tank. When I put hot water on I hear a click in the white nest box but boiler does not fire.
10-20-2023 01:12 AM
Any advice ?
10-20-2023 10:06 AM
@TudorL Can you help me ?
10-24-2023 12:24 AM
Hi there and sorry for the delayed reply. Would it be alright if I send you an email on the address associated with your Community account?
10-24-2023 03:51 PM
Yes that would be fine.
10-25-2023 12:50 AM
I sent the email your way. Make sure to let us know here once you've been through it so me or one of my colleagues can check it.
10-28-2023 01:05 AM
Hi there, just checking in with you. Did you manage to check the last message?
10-30-2023 01:35 AM
I haven't heard from you in a while so, if you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community. Thanks, Larisa.
