07-09-2024 10:41 PM
We can get hot water only by using the Nest Heat Link in manual override; which means our central heating kicks in as well; There is no option to manually override for hot water only!
Nest provided a new Heat Link which the Electrician installed. After a lengthy call to Nest support he reset the thermostat but the same problem continues.
The “continuity test” requested by Google Nest showed no errors
We have a 2 year old Worcester Bosch conventional boiler.
Nest support suggested calling a NEST PRO engineer but I’d have to pay & reclaim.
Any constructive ideas appreciated
07-14-2024 10:13 AM
Hi @TheNavigator,
I understand how frustrating it must be to have limited control over your hot water system. It sounds like you've already taken some steps to troubleshoot the issue, but the problem persists. Let's work together to find a solution.
To better understand the situation, could you please clarify a few points:
Additionally, have you tried contacting your boiler manufacturer (Worcester Bosch) for any specific guidance on compatibility with the Nest Heat Link? They might have insights into potential issues or workarounds.
I'm here to help you find a solution. Please feel free to share any additional details that might be relevant.
Mario.
07-09-2024 10:26 PM
