06-04-2024 08:36 AM
My Next thermostat was working fine for a year or so. Then suddenly I get a no power warning. It would intermittently start again and work fine for a few days then no power again. I checked all the wires, did a factory reset and not it says all of the wires are undetected. I had an HVAC technician come out and he couldn't figure it out. Everything is wired correctly and functioning just not the thermostat. I've seen many posts of others having the same issue but no resolve.
06-04-2024 11:31 AM
I’m having the same problem!
06-04-2024 05:17 PM
I'm having the same problem. There is 24 volts at C wire, set up says there isn't. I've reconnected it several times. I received an email saying I need a replacement Thermostat, How do I get one???
06-07-2024 11:35 AM
Hi there!
Thanks for reaching out to the community about your Nest Thermostat. We understand it can be frustrating when your thermostat doesn't recognize the wiring. Don't worry, let's see if these troubleshooting steps can help:
Important Safety Note: Before you begin, always turn off the power to your Nest Thermostat at the breaker box.
Troubleshooting Steps:
If you've completed these steps and your Nest Thermostat still doesn't recognize the wiring, please contact our specialist team for further assistance. They can help diagnose the problem and find a solution.
We'll be happy to help you get your Nest Thermostat functioning properly again. Feel free to keep us updated on the situation.
Douglas
06-07-2024 08:02 PM
This did not work. Thermostat still is not getting power so once the manual charge runs out that I have to do every single day to cool off the house in the afternoon, we again have no thermostat which means no air conditioner!
06-08-2024 10:01 AM
Hello @DbaChris,
Thanks for your reply. I apologize to hear your Nest Thermostat isn't charging. I'm happy to help you.
To expedite the process, please fill out this form to create a new support case. Once submitted, our team will review your information and determine if a replacement thermostat is the best solution.
We'll follow up on your case after you submit the form. Keep posting when you comply with that, and i will definitely do my best to help you.
Douglas.
