No power to rc
Fmdial
I have dual transformers.  Originally rh had no power so electrician changed to common wire on ac handler.  Now rc no longer has power whereas before he changed to c wire it was.
Hi Fmdial,
Thanks for reaching out. Let's sort this out.
Could you please share the photo of your old and new wiring? Also, check the power readouts with or without your C wire. To check it go to "Settings" and look for "Technical Info" then select "Power".
I'm looking forward to your response.
EmersonB
@Fmdial I'm dropping by to ensure that everything is covered here. How's it going with your Nest Thermostat? We would appreciate it if you could share with us the information we're asking above. Don't hesitate to give us your update here.
I appreciate the help, Jenelyn.
EmersonB
Hey Fmdial,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
