Not cooling after installing nest thermostat
TwoDayBender
Installed as described. Went through test for heat and cold. Then set for cooling. A/C not cooling. Any ideas are greatly appreciated.
Can you post a picture of how the original thermostat was wired?
Which Nest thermostat do you have?
Ryan_G
Hey TwoDayBender,
It's great to hear that it is working now. If you have any other concern, let us know by creating a new thread as this one will now be locked.
Thanks for your help, Patrick_Caezza.
Ryan
TwoDayBender
Problem solved. Thank you all.
