01-20-2025 06:51 PM
Both of my thermostats stopped showing correct outside temperature. It shows correctly in the nest app.
I have disconnected and reconnected both to the nest app. Still incorrect.
Wifi connected.
Both show same incorrect temperature.
01-24-2025 02:46 PM
Hi Sam94550,
Thank you for reaching out to the community. I understand your frustration that both of your Nest Thermostats are not displaying the correct outside temperature. Let's work together for a solution.
To help me troubleshoot this effectively, could you please provide some more information?
What specific models of Nest Thermostats are you using? (e.g., Nest Thermostat, Nest Learning Thermostat, Nest Thermostat E)
When were your Nest Thermostats installed?
Where are your thermostats installed? (e.g., in the living room, on an interior wall)
When did you first notice the incorrect outside temperature readings?
How much does the outside temperature displayed on the Nest Thermostat differ from the actual temperature shown on another reliable thermometer or weather source?
Is the incorrect temperature displayed continuously, or does it occur under specific conditions?
Have you made any recent changes to your HVAC system (e.g., service, filter replacement, system upgrades)?
In addition, please check the following:
Nest Thermostat Network Connection: Go to Settings > Technical Info > Network on your Nest Thermostat. Note the signal strength value. A weak signal can sometimes affect weather data retrieval.
I look forward to hearing from you and assisting you further.
Kevin
