07-27-2024 11:50 AM - edited 07-27-2024 12:04 PM
Hello all, I have a RUUD HVAC system that uses 8 wires, including P1, P2. I was wondering if I need these wires work with the google nest (and whether they need to be connected) or whether they can just be taped off? On the panel of the back of the thermostat, it says: "Required Return Air Plenum Sensor (must be installed)" I have included a photo here: https://photos.app.goo.gl/9sH3p4uDRTBht4ys7 Thanks in advance for any help.
07-30-2024 12:16 PM
Hello @gribensk
Thank you for reaching out to our Nest community about this compatibility situation. I'm happy to help you with it.
I really appreciate the image and information you shared with us. Unfortunately, it is difficult to find an answer for this wiring configuration. To avoid making any mistakes and to be 100% sure about this compatibility, I recommend you contact a Nest Pro to check if these wires can work with our Nest thermostats.
You can enter here to find a Nest Pro.
Please feel free to continue posting information about your device; we're here to help.
Douglas.
