02-05-2023 07:57 PM
02-05-2023 08:07 PM
Check if your furnace power switch and breaker is on. It gets the power from the transformer in the furnace or boiler. If main power is on then you would need a multimeter (you can buy an inexpensive one at harbor frieght tools or home depot etc) set it to test for AC volts and test for power on the Red and White wires at the furnace system wires. If nothing then maybe the transformer is bad or some other problem and you would need a HVAC tech to diagnose the problem unless you are handy and want to try and replace parts.
02-10-2023 04:47 PM
Hey NeedsAnswers,
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, Houptee.
Archie
02-13-2023 10:44 PM
Archie
02-15-2023 09:26 AM
Thanks for checking, @aatienza. I think I'm good, as I went ahead and completely removed. It's too unpredictable, required change of battery too often, as well as to switch the transformer again. Thanks again for trying. But, I'm not confident in this product to keep my family safe and warm during the cold winter months.
02-16-2023 12:04 PM
I understand the trouble you were having. I am going to go ahead and lock the thread in 24 hours in case you have any follow up questions.
