2 weeks ago
I have a two-wire battery operated thermostat and want to replace it with a 3rd Generation Nest Learning Thermostat to heat up my house using a boiler.
I have come across three methods to achieve this on the internet using a plug-in 24V transformer and want to know which is the correct and best way:
Method 1:
Nest Rh to R on Boiler
Nest W1 to W on Boiler
Nest Rc to 24v Plug-in Transformer
Nest C to 24v Plug-in Transformer
Method 2:
Nest Rh to 24v Plug-in Transformer
No Contact to R on Boiler
Method 3:
Nest Rh to 24v Plug-In Thermometer
Nest C to 24v Plug-in Thermometer
a week ago - last edited a week ago
Hi @4head,
Thanks for reaching out to the community! I understand that you’re looking for the best wiring recommendation to replace your two-wire battery thermostat with a Nest Learning Thermostat 3rd Generation. Let me help you find the best option!
Before we move forward, I need some information to provide you with the most accurate steps:
Once you provide this information, I will be more than happy to assist you!
Debora
