06-20-2022 09:18 AM
Hi Folks, we have just had a new boiler system installed in our house. Our old system had a simple wireless thermostat powered by two AA batteries.
We have now just installed a NEST Learning Thermostat which works when connected up directly with a USB cable to power it. But when we put it on the base plate it shows an error message. We now understand that the internal battery needs charging up - which we are doing. But how long will this charge last?
The instructions keep referring to wires from the old thermostat but there aren't any - it's wireless. That's why we bought this NEST device because that's wireless as well. So not being able to put an AA battery in it is quite a nuisance and I feel we are going to struggle keeping it charged up.
Any advice would be appreciated?
06-25-2022 01:25 AM
Thank you for the information @RintyMon . I would be happy to try and assist you.
You mentioned you get a message on the display? Would you be able to take a picture of that?
Also to clarify, all of our thermostat models are designed to work when constantly connected to power, they will not run of the internal battery as that is just to retain settings and to keep power for a bit if moving locations.
06-28-2022 04:34 AM
Hi @RintyMon. Did you manage to check my colleague's message?
06-29-2022 06:53 AM
06-29-2022 07:05 AM
Hi there again @RintyMon
Thanks for getting back to us and providing all these details. In order to be able to understand the issue with your thermostat, would you kindly provide me with a few pictures of the device? It will help me see the big picture. Feel free to attach as many pictures as needed so I can see clearly what you're trying to explain.
Thanks a lot for your cooperation.
06-29-2022 07:35 AM
Hi, I’m struggling to upload the photos I’ve taken but basically it is as I’ve described; a Google Nest Learning Thermostat plugged in using a USB cable. Do you have any suggestions regarding the point I made earlier i.e. we didn’t expect to require a voltage supply when purchasing a wireless thermostat? We expected to simply power it with batteries - because it’s wireless..
06-29-2022 10:06 AM
We understand your confusion, but as my colleague states, your thermostat won't be able to hold the charge if you keep it unplugged, this is how it was designed. The thermostat is indeed wireless, as it is connected to the internet and to the Heat Link wirelessly. If you have it installed on the wall, you can purchase a stand separately and that way you'll be able to move it around easier and place it wherever you like, but it will need to be plugged into a power socket with a micro USB cable.
07-02-2022 04:11 AM
Hi, I wanted to check in. Is there anything else I can try and assist with? If so, make sure to let me know.
07-04-2022 06:08 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
