10-26-2021 09:28 PM
What’s happening is my primary heat is set to electric problem is where the setting for to change it to gas is disabled I tried factory resetting and everything.
10-26-2021 09:33 PM
It’s the Heat fuel source it’s just disabled here is a picture.
01-27-2022 01:12 PM
I have the same problem...
Did you figure it out?
12-08-2022 11:24 PM
I also have this same problem, any luck here?
12-12-2022 12:39 PM
Hi bluebird,
Thanks for reaching out. I'd love to know more about this. Could you share a photo of your current thermostat's wiring?
Mel
12-13-2022 04:19 PM - edited 12-13-2022 04:21 PM
Nevermind, got it figured out. Turned out to be a problem with the setup. I have an AC unit + gas heater and had been setting it up the heat as single fuel system, but that made the heat only work on emergency. I reset it and set it up as a dual fuel and that allowed me to choose alternate heat as a the primary source so now it ignites the burner for normal heat. Thanks!
12-13-2022 07:17 PM
Hey bluebird,
That's great to hear! Let us know if you have other questions as I'll be locking the thread after 24 hours.
I appreciate the help, Mel.
Archie
