11-17-2024 03:07 PM
I have a similar problem with my nest thermostat, which is very old. It does not have a QR code at all. There are no key numbers anywhere. The settings do not take me to anything with a key number. My old Nest app works on my old iPad. It used to work on my iPhone but that stopped working, I don’t want to go all the way back to reset the thermostat & lose the iPad which is the only device that works. The iPhone & iPad are on the same version of the app.
11-19-2024 05:48 AM
To confirm, which model of thermostat do you have?
How to tell which Nest thermostat you have - Google Nest Help
If the Nest app works on your iPad, are you signed into the Nest app on your iPhone using the same account you're using on the iPad? Assuming that's the case, your thermostat should already be there in the app.
You only use the QR code or setup key during setup once. It's not used to add it to additional phones and tablets, you just need to sign in with the same account you used during setup.
11-23-2024 11:18 PM
11-24-2024 04:59 AM
Open the Nest app on your iPad and tap the settings cog at the top right. Tap Account, which will show you the email address you're signed in with. You need to login using that same email in the Nest app on your iPhone.
If it's a legacy Nest account, that you never migrated to a Google account, when logging in on the iPhone ensure you use the "Sign in with Nest" link at the bottom of the screen. If you migrated to a Google account, or have always signed in with a Google account, use the "Sign in with Google" button instead.
If you still don't see your thermostat in the Nest app on your iPhone, let me know and I'll walk you through how to add it to the app again.
11-24-2024 04:56 PM
11-25-2024 11:22 AM - edited 11-25-2024 11:24 AM
Alright, so you no longer have access to the email address you originally used to setup the thermostat. In that case, follow these steps:
Let me know how you get on!
11-25-2024 11:32 PM
11-29-2024 07:56 AM
Apologies, as I edited my post and changed step 1. You need to do the first reset part on the thermostat itself, so on the thermostat itself, press it to open the quick view menu, tap the Settings cog. Go to Reset, then choose Account connection. If you don't see this option, you'll need to select All settings instead.
