03-10-2025 01:47 PM
I have a second home and set my temperature at 55 degrees when I leave. I don't want it to change unless I change it manually. How do I override automatic temperature changes?
03-14-2025 12:07 PM
Hi @Bonniebb,
Thanks for reaching out here in the community! I understand you'd like your Nest thermostat to maintain 55 degrees when you leave your second home and adjust the temperature manually as needed. I'd be happy to help by disabling these automatic temperature changes.
To better assist you, I'd like to ask the following:
In the meantime, I'd suggest checking the following:
Please keep me posted.
Jenniffer
