Settings for Nest Thermostat and Combi Boiler
Tiltonblue
Good day, we could do with some help please, we are trying to use our nest learning thermostat to control the heating, what would you set the timer on the combi boiler. would it be Off, timed or Constant?
Many thanks Mike
Jhonleanmel
Hi Tiltonblue,
By default, your Nest thermostat heats water from 6.00 a.m. to 8.00 a.m. (06:00–08:00) and from 4.00 p.m. to 10.00 p.m. (16:00–22:00).
You can always change your hot water schedule with the Nest app, just like you can change your heating schedule. You can set the time and duration for heating water, as well as set a different schedule for every day of the week. Check this guide on how to control your CombiBoiler.
Mel
Hey there Tiltonblue,
Mel
Juni
We haven’t heard back from you, so I'll be locking this thread in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Juni
